Minneapolis Moline Tractors Discussion Forum
MM Super 670 steering gear housing seeping oil
herald
03-31-2005 16:59:25
I put a new seal and gasket, on the bearing cage, under the steering housing, and now put it back together and it still seeps alittle oil. The 6 bolts that hold the cage to the housing, are they supposed to have gasket sealer on the threads before I screwed them in or did I ruin the gasket putting it together? And how tight do you tighten those bolts? Thanks for any help. Herald
Kelvin
04-01-2005 18:25:13
 Re: MM Super 670 steering gear housing seeping oi in reply to herald, 03-31-2005 16:59:25
I don't know about a Super 670, but on the jetstar steering gear at least 1 bolt hole is drilled through on that steering housing. Kinda makes sense, it works as a drain.
What I'd try before I took it back down is to remove those bolts one by one and clean them and dope the threads with a bead of Permatex #2 and see if that stopped the seep. Of course, you better have a catch pan handy if you find one drilled through.
Herald
04-04-2005 20:45:29
 Re: MM Super 670 steering gear housing seeping oi in reply to Kelvin, 04-01-2005 18:25:13
Thanks Kelvin, got it stopped. Herald
