Minneapolis Moline Tractors Discussion Forum
UB Exhaust
molinegb
03-26-2005 05:51:37
Can someone tell me if UB exhaust manifold and U are the same? I don't have a book but I think UB uses the one like a M5.
Kevin Moschenrose
03-26-2005 09:07:18
 Re: UB Exhaust in reply to molinegb, 03-26-2005 05:51:37
Yes they will work all the same!
Kelvin
03-26-2005 19:46:24
 Re: UB Exhaust in reply to Kevin Moschenrose, 03-26-2005 09:07:18
I think Kevin was trying to say that they will interchange if you use the corresponding intake manifold. For example, a hot spot type U manifold has to have the correct intake runner bolted to it.
A M5 manifold comes in 2 versions: The 1 piece has intake and exhaust cast together and is for gasoline engines. (To mount in a U engine, you may have to remove the air cleaner mount tabs from it.)
The 2-piece M5 manifold is most likely intended for LP, although some are used for gas by intalling a plate from the exhaust manifold to the intake, which transfers some exhaust heat to the intake so the carburetor doesn't frost up.
Kevin Moschenrose
03-26-2005 21:59:31
 Re: UB Exhaust in reply to Kelvin, 03-26-2005 19:46:24
Yes Kelvin that's what I meant I failed to mention that in my post. Thanks for the coverage on that.
