Minneapolis Moline Tractors Discussion Forum
49 UTS W/ LP intake
Texas Red
03-23-2005 02:34:19
I put an LP intake and a set of zoomys on the Uts, I acts like it realy wants to pull, But.... seems to be a little cold natured now. idels a little rough. is there something in the timing to work on after the LP intke. Is there someone who has an LP intake on there UTs with tips on tuning?? thanks for the help TR
Roger in Ks
03-23-2005 05:12:14
 Re: 49 UTS W/ LP intake in reply to Texas Red, 03-23-2005 02:34:19
You have the same problem as Scott(post below). The LP Intake/Exhaust manifold does not heat the incoming fuel mixture. It tries to freeze off. The original gasoline manifold setup helped "atomize" the gas. I have 2 U Molines on Gas with the LP I/E. They run fine in the summer when it is hot. There used to be a company that made an electric heater to put on the LP intake to heat the incoming Gasoline fuel mixture. On one of my U's I ran a water line somewhat like an LP setup. Tapped into the water manifold, ran a hose to the carb, wrapped a copper line around the base of the LP intake just above the carb. then back to the water pump. When the tractor was warmed up in the winter time it would run fine.
