Minneapolis Moline Tractors Discussion Forum
FROSTY CARB ON U MOLINE
Scott Erickson
03-22-2005 12:26:08
Hello, I have a u moline that I can't get the carb to quit frosting up on. I have rebuilt the carb tuned the engine up such as points plugs wire cap rotor and adjusted the valves and timing.
I can start the tractor up in the warm shop and in less than 1 minute the carb is frosting up. What could be causing this. Thanks for your help.
Scott
Bob M
03-23-2005 12:27:06
 Re: FROSTY CARB ON U MOLINE in reply to Scott Erickson, 03-22-2005 12:26:08
Cooling of the carburetor a is normal for any carbureted engine. Under certain conditions of temperature and humidity it causes condensation or frost, just as you have discovered. It's worst between about 32 and 60 degrees or so with high humidity.
Carb icing is hard to eliminate. But if it causes problems (rough running, stalling, etc) you can minimize it's effects:
Upon initial startup get the choke full open as quick as you can. Soon as the engine starts bump it up a few hundred RPM above idle while the engine warms up. Or better yet put it under light load immediately. Adjust the carburetor for the best idle when warm (an too rich idle misture aggravates carb icing). If the manifold has an adjustable hot spot or heat riser, set it to the "hot" or "winter" position. Having working thermostat in the cooling system is a must - the hotter the better!
In severe cases you can duct hot air from above the exhaust manifold into the air cleaner inlet to warm the air to the carb. Also put a winter front over the radiator in cold weather to stop the constant blast of cold air off the fan from cooling the carburetor.
Kelvin
03-22-2005 17:59:50
Which manifold are you using? And how humid is it there? Do you have evidence that its frosting inside?
The reason I ask is if you have an LP manifold on it, there is no provision to conduct any heat down to the carb., like the gas manifolds had. If you notice, about all the MM gasoline manifolds were bolted to the exhaust manifold at some point.
Also, anytime there is a pressure differential in the air flow from high to low pressure the air absorbs heat, the result which you see as frost.
PeteNY
03-22-2005 13:59:48
Scott, My guess is that you have a little gap on the intake side, the cold air will cause it. Pete
