Minneapolis Moline Tractors Discussion Forum
help with model #
Pasbon
03-22-2005 05:42:07
I have located a MM tractor and the model number is hard to read but the serial number is 16900706. I have looked here and can"t find the model anywhere with that serial number. can anyone help?
pasbon
03-22-2005 05:56:15
 Re: help with model # in reply to Pasbon, 03-22-2005 05:42:07
after looking at some pictures it appears to look similiar to an M5
Kevin Moschenrose
03-22-2005 07:17:21
 Re: help with model # in reply to pasbon, 03-22-2005 05:56:15
That's the diesel engine serial number for an M-5
tractor.
pasbon
03-23-2005 09:18:48
 Re: help with model # in reply to Kevin Moschenrose, 03-22-2005 07:17:21
the tractor I am looking at has a propane engine, where is the tractor tag located and about what is it worth with at stuck engine, and one rear tire (18-26) bad. what is scrap worth and what does it weigh? As you can tell I know very little about MM's. The lady said to make her an offer, hence the questions.
Kevin Moschenrose
03-23-2005 22:42:55
 Re: help with model # in reply to pasbon, 03-23-2005 09:18:48
LP yes for sure my bad. I was on the wrong line "169" starts the engine serial numbers 336-4 engines for M5 gas and LP gas and the year is 1961.
Kevin Moschenrose
03-23-2005 22:38:20
The tag for the tractor will be on the transmission housing by the brake pedals on the right side. That tells the true story on the tractor. I am not sure what scrap is paying where you live but here in central Illinois it is 80.00 per ton of clean #1 metal. The weight with no added weights or fluid in the tires will vary a little an lp with type U front axle "narrow front weights 6400 pounds and at new factory list price of $4847.00 and a standard lp gas "wide front" weighs in at 6600 pounds and factory list price of $4696.00 These are facts and figures straight from my MM dealer book dated January 20 1960 Offer her maybe a 1000.00 for it because to me it would be worth it and go from there. That would be better than scrap and seeing how I like to see a picture of it to get a real good price idea. Really that question is something I don't like to answer because it is so open ended. It really is what you are willing to give and she is willing to take for it. A UDLX maybe worth 100,000.00 but if no one is willing to pay that much and I do mean no one well then there you go. I only say this as an example only! My email is open if you would like to chat more about it.
Jim Parisot
03-24-2005 07:38:24
 Re: help with model # in reply to Kevin Moschenrose, 03-23-2005 22:38:20
Kevin,
If no one is willing to pay that 100G for the UDLX then in my estimation it's NOT "worth" it. It must be "worth" something less - let the market decide. And I am using that as an example, also. On items like that anymore I prefer to use the term "valued at". It's like a big percent of that stuff on "Antiques Roadshow", it sure isn't "worth" those prices to me.
Jim
