Minneapolis Moline Tractors Discussion Forum
UDLX need help with cab moldings????
jeffbmw
03-13-2005 16:22:21
We are rebuilding a UDLX. The tractor is done and we are replacing all the glass in the cab area but need some of the rubber that holds the side glass in. we have found the door track.
Any help
jeff
Lurkin Murph
03-14-2005 14:47:53
 Re: UDLX need help with cab moldings???? in reply to jeffbmw, 03-13-2005 16:22:21
Jeff, Check with a glass shop that does automotive
glass work. I am pretty sure that some of the older truck or tractor cab mouldings should work
You might want to take an old piece with you when you go in. Good luck, Murph
