Minneapolis Moline Tractors Discussion Forum
GE 30E heads
moli
03-12-2005 17:37:44
Can anyone tell me what the aprox compression ratio would be if using these heads on the Welters setup of 4.810 x 6.125.
Kelvin
03-14-2005 18:42:24
 Re: GE 30E heads in reply to moli, 03-12-2005 17:37:44
The cubic inch volume of the combustion chamber in the heads is posted on Jeremy Fiorelli's tractor pulling website.
To calculate compression ratio:
Total cubic inch volume = ( (radius of piston)x (radius of piston) x 3.14 x stroke + cubic inch volume of combustion chamber in the head.
[Remember, radius is 1/2 the diameter.]
This gives you total volume of the cylinder and combustion chamber with the piston down.
Now divide this number by just the combustion chamber volume. This will give you the compression ratio 'to one'.
JK2
03-14-2005 18:38:14
GE30E heads are the same as GE30F, GE30H, GE30W and 10A4209. The following compression ratios and pressures are as below for the applications shown:
Engine Ratio Cranking Pressure
283-425 5.5:1 95-115
403-605 7.3:1 130-150
336 6.5:1 120-140
From these figures , I would assume that you would approach 7.6:1 with that setup if piston to deck height is close to a 403 (4.625x6).
John
