Minneapolis Moline Tractors Discussion Forum
Stuck energy cell body
Old G
03-06-2005 06:01:00
I have one bad energy cell that needs to come out. With everything on the plug side removed, the body will not even drive out from the injector side. Been soaking it but it won't budge. It is eroded but the head is very good. Does anyone have an easy fix? If it was something other than a cast head, we would heat it but I'm not sure how much heat I dare put on this. Can it be drilled carefully or what else is there. Thanks for any help.
george md
03-06-2005 10:56:42
 Re: Stuck energy cell body in reply to Old G, 03-06-2005 06:01:00
Old G,
Do you have the proper puller on the outside
of the head ? also set it up on edge and soak with 2+2 or other carbon dissolving agent (a
carb gum cutter ), then with the puller applying
force tap from the inj side with brass punch.
george
