Minneapolis Moline Tractors Discussion Forum
670 diesel heads
tntractor
03-02-2005 09:54:50
I am trying to repair a 670 diesel for a neighbor. and both heads are cracked. I believe that they were both welded before. Does anyone have any GOOD used heads or know where I can get some? The front head has several cracks, and the rear is only cracked (what I have seen so far) between the valves. Thanks in advance.
Mopower
03-03-2005 20:13:27
 Re: 670 diesel heads in reply to tntractor, 03-02-2005 09:54:50
I have a set of those heads off a good engine. Gimme a call if you like. $475 for the pair +shipping. 517-726-0484
-Ethan
Jake Winn
03-03-2005 10:15:12
Hello, I am going through the same thing with a friends 670 as well. They were both cracked between the valves on all cylinders. Heads are somewhat easy to find. What is your part number. The earlier heads will also work, i believe they are 4222 heads. I have one left off of an earler 504 engine that i would sell. Email me for more info.
tntractor
03-04-2005 21:34:39
 Re: 670 diesel heads in reply to Jake Winn, 03-03-2005 10:15:12
The casting number is 10A23134.
