Minneapolis Moline Tractors Discussion Forum
Gvi
John in Utah
02-23-2005 20:17:33
As near as I can tell, one battery that the Gvi uses is a 3EEE, does anyone know what the other battery is, or is there two more? Also does anyone know the weight of a GVI? thanks
Glen in TX
02-27-2005 10:25:24
 Re: Gvi in reply to John in Utah, 02-23-2005 20:17:33
A equipment guide I have says 7,620 for LP and 7,835 for diesel.
James2
02-24-2005 09:35:00
If it is a diesel GVI, it uses three batteries all the same size. Two on the right, one on the left. Weight I don't know, I suspect around 8000 lbs with no weights.
John in Utah
02-25-2005 08:02:55
 Re: Gvi in reply to James2, 02-24-2005 09:35:00
Thanks for the info, It is a deisel and I figured it would weigh around 8500. That would make sense that it would take three batteries as the platform for the right side batteries is twice as wide as the left side. Thanks for the info, as soon as the snow melts down from 4 feet I will go get it.
Mopower
02-24-2005 06:18:53
I believe a GVI is around 8200 pounds but that MAY be without big wheel weights.
Ethan
