Minneapolis Moline Tractors Discussion Forum
LEAKING EXHAUST AT BLOCK BF IXB-3SL HERCULES
CLAUDE
02-22-2005 23:01:31
HAVE SMALL EXHAUST LEAK AT BLOCK AND MANIFOLD, WOULD THIS HURT ANYTHING, RUNNING THE TRACTOR IN THIS CONDITION. DOES THE MANIFOLD HAVE GASKETS.? AND ALSO HOW MUCH HORSEPOWER DOES A HERCULES IXB-3SL, HAVE!!!. 3 1/8 INCH BORE.
Ryan
02-25-2005 08:06:23
 Re: LEAKING EXHAUST AT BLOCK BF IXB-3SL HERCULES in reply to CLAUDE, 02-22-2005 23:01:31
We had one leaked for years, so when we put back together we used to manifold gaskets back to back. Also, use a sealant, you can get it at an auto parts store it is high temp, orange tube. Your other option which has been mentioed is to take it to a machine shop and have them plane the manifold down some so it all matches. Good luck. Can"t tell you on the horsepower, I would guess 14-17?
Ryan
george md
02-24-2005 19:03:44
Claude,
If resurfacing doesn't fix it and you don't find one , I can build it up so that you can resurface it
george
Keith Ault
02-23-2005 13:18:35
I had a similar problem,manifold had a terrible warp,took to machine shop and had surface planed ,use new gaskets.Hope this helps
