Minneapolis Moline Tractors Discussion Forum
BF AVERY Stuck Clutch
Walter Nelson
02-22-2005 19:16:59
My Minni Mo model BF has a stuck clutch. I figure I will have to replace the clutch. Looks like I can slide the tractor apart enough to work on the clutch, am I right?. Any advise or suggestions would be appreciated from my Minni Mo brothers. Can a new clutch be had anywhere? Could I have it rebuilt at NAPA? I am willing to buy a manual.3606750112 Oak Harbor, WA
CLAUDE
02-22-2005 22:18:29
 Re: BF AVERY Stuck Clutch in reply to Walter Nelson, 02-22-2005 19:16:59
YES. MAKE SURE YOU MARK THE WIRES, HAVE WRING DIAGRAM IF NEEDED, LIKELY THE CLUTCH HAVE BEEN REPLACE BEFORE,AND THE CLUTCH FOOT PEDAL HAD NOT BEEN ADJUSTED, IT MUST BE ADJUSTED WITH A NEW CLUTCH , ABOUT 2INCHS, ON THE ROD ITSELF, USING HEATING TORCH AND OIL.HAD THE SAME PROBLEM. IT WAS STAYING IN GEAR, WHAT IT IS THE RELEASE BEARING IS CATCHING ON END OF CLUTCH SHAFT. I HAD TO REPLACE THE PRESSURE PLATE, BECAUSE OF THE FINGERS, SO I RELINE THE CLUCH ALSO. AND CHANGE ALL BEARING. BOUGHT BEARING FROM NAPA, AND CLUTCH, NEW PRESS PLATE AND TURN THE FLYWHEEL AT MARGOT, BATON ROUGE, LA.
Jerry Cent. Mi.
02-24-2005 05:36:31
 Re: BF AVERY Stuck Clutch in reply to CLAUDE, 02-22-2005 22:18:29
Are you sure that its not rusted to the flywheel?
The disc's have a tendency to do it and in a lot of cases it can be loosened without teardown.
