Minneapolis Moline Tractors Discussion Forum
335 engine problems
kas
02-15-2005 18:29:46
Purchased a 335 with backhoe and loader. Upon removing the head one of the cylinder walls was cracked. The block still held antifreeze but an exhaust valve was open and the cylinder filled with water. Are parts available or is this a parts tractor?
Kelvin
02-15-2005 18:50:02
 Re: 335 engine problems in reply to kas, 02-15-2005 18:29:46
If it were mine, I would see if a machine shop could re-sleeve that cylinder and bore it back to fit your old piston. Course you have to take it apart to get the block out. I've got a 206 engine with a repair sleeve in 1 cylinder and some larger engines with repair sleeves that have given no problems.
I know rings and bearings are no problem. Don't know about pistons, or even if you need new pistons.
At worst case senario you can install a complete 206 engine (like the 445 used) or you can install 206 crank, blocks rods and pistons and use your old crankcase and heads. I do know 206 oversize pistons are available.
Slow Mo57
02-18-2005 07:30:59
 Re: 335 engine problems in reply to Kelvin, 02-15-2005 18:50:02
I have a 445 & would like to talk to you about bigger pistons.How big can you put in stock block?How far can you mill stock head down to? Do you have a big bore 445 engine for sale? I work 2nd shift in IN. give me a call Or Email or reply please thank you.Phone # 260-238-4684 .If you call I will call you back.
THANK YOU John
Kelvin
02-18-2005 19:11:07
 Re: 335 engine problems in reply to Slow Mo57, 02-18-2005 07:30:59
SloMo, I don't have any personal experience hopping up 206 (445) engines.
I understand from reading this board that you can go from the standard 2-5/8" bore to 2-3/4+.060 most times without problems, and I think pistons are available to do this. I say 'most times' because you'd be cutting almost 1/8" out of the cylinder wall and may hit water.
Slow mo 57
02-19-2005 07:34:08
 Re: 335 engine problems in reply to Kelvin, 02-18-2005 19:11:07
Thanks
