Minneapolis Moline Tractors Discussion Forum
mm rtu year model
SWC
02-13-2005 17:57:14
I have bought a rtu with ID tag rusted out. Need help with year model. Engine tag ser# 210749. Tractor also has magneto. Thanks.
JK2
02-15-2005 04:01:55
 Re: mm rtu year model in reply to SWC, 02-13-2005 17:57:14
If the tag is rusted out, how do you know it is an R? Ways to tell an R from a Z is that the brakes on an R are located inside the axle housing near the rear end while the Z's brakes are external, above & in front of the axle housing. R brake pedals are in front of the axle & Z's are behind the axle.
John
JK2
02-14-2005 16:46:51
Engine serial number 210749 is for a 1945 206-4A engine which is not what is supposed to be in an RTU. An RTU should have an EE engine. I would say it is very likely that someone has replaced the engine, assuming that it is in fact an RTU.
SWC
02-14-2005 17:29:46
 Re: mm rtu year model in reply to JK2, 02-14-2005 16:46:51
I"m not very familiar with MM classifications. Tractor is tricycle row crop style. Please advise on proper classification. Any help would be appreciated. I need to know which R model so I can order correct manuals. Thanks.
