Minneapolis Moline Tractors Discussion Forum
ZAU STEERING SHAFT GROOVE PIN REMOVAL
JKC
02-12-2005 18:21:54
I am trying to remove the steering shafts from my 1950 ZAU and cannot figure out how to remove the "groove pins" (page 83 of the parts book) that connects the shafts to the universal joint on the left side of the tractor? Any help would be much appreciated.
JKC
02-17-2005 08:44:29
 Re: ZAU STEERING SHAFT GROOVE PIN REMOVAL in reply to JKC, 02-12-2005 18:21:54
Thanks to all who gave me some pointers on this issue. I had no problem removing the pins. As I continue in this restoration field, I continue to be amazed at how much help HEAT can be to loosen things up. I heated things up and the pins popped right out! Thanks again!
BLT
02-14-2005 20:38:16
Go to a hardware store and buy you a roll pin when you get ready to go back with it.
JKC
02-14-2005 16:51:14
OK, the next question is:
If you take these pins out, does AGCO make a replacement for them?
Thanks.
Augie
02-14-2005 18:24:19
 Re: ZAU STEERING SHAFT GROOVE PIN REMOVAL in reply to JKC, 02-14-2005 16:51:14
If you don't booger the old one up too bad taking it out you should be able to re-use it.
Spud
02-14-2005 15:51:06
I drilled mine out Took all of 20 min.
Alan K
02-13-2005 20:16:40
If I remember correctly they are tapered pins, at least they were on our ZA. They need to be drove out one direction.
Alan
Augie
02-12-2005 19:11:50
You need a rosebud tip for your torch and a big hammer.
Kelvin
02-13-2005 09:31:11
 Re: ZAU STEERING SHAFT GROOVE PIN REMOVAL in reply to Augie, 02-12-2005 19:11:50
And a punch, to drive the pin after you heat everything.
Augie
02-14-2005 08:45:30
 Re: ZAU STEERING SHAFT GROOVE PIN REMOVAL in reply to Kelvin, 02-13-2005 09:31:11
Yep. A wooden block to support the shaft and a pair of thick leather gloves help too.
