Minneapolis Moline Tractors Discussion Forum
value of a Jet Star 3......
Ken-Mt
02-04-2005 16:17:17
A guy wants to sell a MM Jet Star 3 44 Super.It's got power steering,new ft tires,80% rear tires,and excellent sheet metal,according to him.It also has a knock,and it sounds like the thrust brg is bad.The tractor is about 300 miles from here,so before I go look at it,I'd like some input. 1.Are these good tractors/worth fixing up? 2.Assuming the motor can be rebuilt,what's a ballpark value? I realize if it's got a spun main,or something like that,it's not worth much of anything.
He said to make him an offer-maybe I'll start at $10 !
Paul Blaney
03-06-2005 07:43:02
 Re: value of a Jet Star 3...... in reply to Ken-Mt, 02-04-2005 16:17:17
As owners also of a MM Jetstar 3 Super, we read through Kelvins response to the value of the tractor. What are you referring to when you mention the "TA", and it being a weakpoint?
mattl12
02-08-2005 14:15:48
where are you located and where is the tractor located? I had two delivered from KY to iowa and have only about $1000 stuck in both. THey are great little tractors. I would be interested in it if you are not.
Matt
Kelvin
02-04-2005 17:32:31
I don't usually respond to this kind of message.
But:
At a penny a pound for scrap, its worth $400. If you have to rebuild it, expect to have at least $1000 in the overhaul. So if you're asking if its a good investment, no.
But:
If you want a tractor that is not real common (not terribly rare, either) and can do about as good a work as a new one and a whole sight cheaper, then maybe you should consider it.
BTW: The TA is a weak point.
