Minneapolis Moline Tractors Discussion Forum
U Diesel
Roger in Ks
02-03-2005 16:32:32
I am going to look at a U Diesel. You know the story, ran when parked. The motor is not stuck. I am guessing it needs a block and head. Will the heads from a G or GB diesel fit? Any other MM diesel heads fit on this thing??? Does anyone have a spare head lying around??? I am in LP Gas country and not many of these around here.
roland witherspoon
02-05-2005 06:35:40
 Re: U Diesel in reply to Roger in Ks, 02-03-2005 16:32:32
i have a set of blocks and heads for a ub diesel in michigan they were at machine shop and are clean but will need the usual honned and valves done
Mopower
02-04-2005 12:24:19
Roger, G or GB diesel heads are the same. I have a set of 10A4222 diesel heads with injectors to sell. These are the same, but you need bigger 4.625 blocks from the 336 engine. They al bolt together as easy as legos.
Roger in Ks
02-04-2005 14:03:27
 Re: U Diesel in reply to Mopower, 02-04-2005 12:24:19
I am going to look at the tractor again tomorrow. Will try to determine if it needs a head. Where are you located?
I have my e-mail unblocked now.
Thanks Roger
