Minneapolis Moline Tractors Discussion Forum
670 water leak
tntractor
01-30-2005 21:14:18
I have a 670 diesel that is getting coolant into the crankcase. My feeling is that there is: head gasket leak, a crack in the water jacket, or water pump seal is leaking. Now, the question becomes, waht is the most efficient way to sort this out to determine where the leak is? Any help will be appreciated.
thanks a bunch, Bud
todd08
01-31-2005 11:20:17
 Re: 670 water leak in reply to tntractor, 01-30-2005 21:14:18
First thing I would do is take a piece of wire and run up the weep hole on the waterpump, make sure it is open and plugged by stop leak or grease. If it drips there then I would R/R the waterpump. They don't cost much to rebuilt. Does it ever miss out on start up or blow water out exhaust, if that is the case then I would bet on a cracked head.
tntractor
01-31-2005 20:20:50
 Re: 670 water leak in reply to todd08, 01-31-2005 11:20:17
It will be going into the shop this week. I will try the weep hole first. I am not sure if it threw water or not. Thanks for replying.
bud
