Minneapolis Moline Tractors Discussion Forum
minneapolis moline ubspecial throttle linkage
gurtie
01-26-2005 14:41:52
I recently purchased a m/m ub special and the throttle linkage is someones jimmy rigged handiwork. Would like an original/replacement or info on what other models have/used the same piece. Meaning does a ub or u or ubd use the same piece. It is the section from the carb to the platform.
thanks
Jim Parisot
01-31-2005 13:51:30
 Re: minneapolis moline ubspecial throttle linkage in reply to gurtie, 01-26-2005 14:41:52
gurtie,
Congrats on buying a really neat and fun tractor to operate. The UB tractors used the same linkages on the gas, all-fuel and LPG as the UB Special. You'll need the two pieces of linkage (rods) and the bell crank that mounts on the fulcrum bolt that mounts on the side of the transmission case. Hope this helps "Git-R-Done".
Jim
