Minneapolis Moline Tractors Discussion Forum
335 Water pump
zjent
01-23-2005 16:55:08
Does anyone know where I can get a water pump for a MM 335. The bearings and seals went out on mine and after disassembling it I found the impeller had two of the six arms broken off. The housing appears good however. The parts' sites list nothing for the cooling system. Thanks for any help you can give.
R.D.F.
01-24-2005 10:58:31
 Re: 335 Water pump in reply to zjent, 01-23-2005 16:55:08
We stock NEW water pumps for those tractors as well as recored radiators, belts etc. Email us or call 920 295 3278, Dale
Tim Bush
01-24-2005 08:24:51
I am at Watertown SD and rebuild the water pumps for MM tractors. Normal turn around is two days unless you come in with it then I like to do them right away so you can take it home with you. Been working on MM for 25 years and my father and grandfather were the MM dealer and transfer point. Have a fair amount of NOS parts. Call my shop at 605-886-9502 or cell 605-520-2429 and I can help you out. Thanks Tim
Floyd Self
01-24-2005 09:53:00
 Re: 335 Water pump in reply to Tim Bush, 01-24-2005 08:24:51
Tim,
What do you charge for a rebuild on a gas 206 pump that is on a Jet Star 2?
Also, I've been trying to find some other pieces for the Jet Star if you think you might be able to help me they are the top and left side hood pieces and a wiring diagram for the instrument panel and engine.
I've been told some other models (maybe even the (335) have the same sheetmetal, but I didn't get any responses on the MM site for help.
Thanks, Floyd in Texas
grandfield
01-23-2005 18:26:07
Try Welters 417-498-6496 any one of the guys or gals there can help you.
dmw
01-23-2005 18:22:50
Rich Cini Phone 724-535-0338
