Minneapolis Moline Tractors Discussion Forum
MM UTSD Clutch needed
david smith
01-19-2005 21:13:10
Hello guys i started working on my uts diesel today got the tractor split and i discovered that i need a clutch plate for it does anyone have one out there for sale by chance? It measures about 12 inch diameter, and it is a 10 spline shaft that goes through it. thanks for your help guys
Kelvin
01-20-2005 18:14:44
 Re: MM UTSD Clutch needed in reply to david smith, 01-19-2005 21:13:10
I'm thinking that if its the same as my '54 U standard diesel, that clutch plate uses the same linings as a UB (But the plate itself is different).
I'm thinking your clutch should have 2 eccentric bars about 5-6" long, one on each side, with bars back to a collar that engages and releases the clutch. Does this sound right?
Bob M
01-20-2005 05:11:32
David - I had excellent luck with my local heavy truck clutch & brake outfit. For $60 they completely refurbished and relined my tractor's worn out clutch disc. And they had it ready in 24 hours.
