Minneapolis Moline Tractors Discussion Forum
Sticky Valve?
JKC
01-16-2005 20:30:13
I have a 1950 MM ZAU that I have been told probably has a "sticky" valve. What is the most likely cause of this? What should I be looking for as the culprit component?
What are some of the "symtoms" of a "sticky" valve?
Thanks.
deadeye
01-18-2005 15:10:15
 Re: Sticky Valve? in reply to JKC, 01-16-2005 20:30:13
Compression tester may help you isolate the cylinder that it is on, if you have one. It may be more than one if the engine has been setting for a while. When changing oil, instead of putting in all of the recommend oil, hold out a quart and then add a quart of Marvel Mystry Oil. Or better yet add a quart of Mystry oil to the old oil, run until it is good and warm, then change. It sure won't hurt it any either way you do it...deadeye
Kelvin
01-17-2005 18:52:12
backfire out the intake or explosions in the exhaust manifold.
poor idle with no other cause. (like fuel mix or weak spark)
weak power from 1 cylnder.
These are a few possible symptoms of a "sticky valve" or valve trouble in general.
What i understand a sticky valve to be is a valve that doesn't close/seal completely every time. Can be due to too close tappet clearance, weak spring, or eroded valve or seat.
