Minneapolis Moline Tractors Discussion Forum
MM 5 bottom plow
Kevin Moschenro
01-13-2005 07:18:37
Is there much of a demand for an MM 6 botton 14" plow that can be dropped to a 5 bottom? One is coming up near me and I would hate to see a scraper get it!
Stewart French
01-13-2005 16:55:20
 Re: MM 5 bottom plow in reply to Kevin Moschenrose, 01-13-2005 07:18:37
I have been looking for a 5 bottom plow where is it going to be and when 515-370-2304
Lindsey
01-13-2005 11:21:20
Kevin, have you seen the plow? I have a 2-14 that I am looking for landsides, and moldboards for as the ones I have are pretty well used and lots of wear. Have new shares so want moldboards to match up on thickness so they would have to be pretty decent.
Kevin Moschenrose
01-13-2005 22:13:40
 Re: MM 5 bottom plow in reply to Lindsey, 01-13-2005 11:21:20
The sale is this Saturday just north of Greenville Il. I havn't seen the plow either. I thought it was odd how there was this MM plow and some MM suitcase weights and MM banana weights listed but No other MM equipment. I thought it might go cheap is all. The rest is JD.
01-13-2005 23:00:40
 Re: MM 5 bottom plow in reply to Kevin Moschenrose, 01-13-2005 22:13:40
third party image
Kevin, I sure wish that sale was closer as I'm hunting MM suitcase front weights for my G-1000 Vista Wheatland.Let us know how stuff sells. I'd say the plow is well worth buying.We used to have a MM semi mounted 5x16 plow that we pulled with our G-900.In fact here it is plowing alfalfa sod in 1969.Thats my 13 yr old little brother running it.He had jumped off the M-5 LP MM pulling 3x16's so I could get a picture of the 900 which I drove.
galenv
01-13-2005 16:00:59
Depends on the model wether parts will interchange. I have some CY landslides and moldboards. [email protected]
