Minneapolis Moline Tractors Discussion Forum
mm utu super C tractor
Bill Houston
01-11-2005 16:51:13
My son in law recently bought a utu tractor sn 331055u with a kef engine. how do we determine the year model? Also it has super C on yhe cowling.It needs to be timed,can any one help?
Kelvin
01-11-2005 18:56:25
 Re: mm utu super C tractor in reply to Bill Houston, 01-11-2005 16:51:13
A quick look at the serial list on this site says your U is a '47. (look under U & UT). MM changed their serial number arrangement on the U three times during its production.
Timing mark is on the flywheel, and viewed through the clutch inspection cover on the left side. Actual firing is supposed to be 3-7/8" before TDC for gasoline. [someday I'm going to figure what this is in degrees, so I can use an adjustable advance timing light.] The timing pointer is the pointy bump on the flywheel side of the inspection hole. (You actually measure back around the flywheel and put a mark 3-7/8" before the TDC mark.)
