Minneapolis Moline Tractors Discussion Forum
MM GB LP
Tracy Redd
01-10-2005 20:29:30
How heavy the GB wieght. It has LP gas, 4 rear wheel weight, no pto, and no hyd.
How heavy with out wheel wieght (rear)
Thanks
Tracy
Monkeywrench2
01-14-2005 08:59:33
 Re: MM GB LP in reply to Tracy Redd, 01-10-2005 20:29:30
Is there a history available for MM? Weights and HP, etc?
John McLucas
01-11-2005 16:08:01
Factory Total Weight on 15-34 tires without weights or ballast was 7400 pounds For GB Diesel (6 cyl 425 cu/inch.) Similar weight for GB gas/LP was 6600 pounds and LP was rated 74 belt HP/ drawbar HP which was advertised in 1955 as highest HP tractor available (4 cyl. 403 cu/inch.) Note these were the smallest tires - more common was 16-34 or 18-26 on gas/lp.
Factory weight options 400 or 650 pounds each weight and common was to use double 400 each rear. Front weights 55 pounds each - I think that was per weight inboard & outboard. Plus there was a chin weight. Ballast added nearly another 1000 pounds per rear - not uncommon to see top of 11,000 pounds maxed out with all weights.
ylw wrench
02-01-2005 18:35:52
 Re: MM GB LP in reply to John McLucas, 01-11-2005 16:08:01
are there any after market axle hubs for the GB to put 9 bolt rims on to cut the weight? Or what diameter is the spline axle to have hubs made? Is it a straight spline or tapered?
