Minneapolis Moline Tractors Discussion Forum
Carb. on Moline
NIC Vondenstein
01-10-2005 18:27:39
I was wondering if anyone could help to inform me about how I can convert my MM 670 Super from propane to gasoline. Any info. would be greatly appretiated. Thanks
WayneT
05-12-2005 19:23:40
 Re: Carb. on Moline in reply to NIC Vondenstein, 01-10-2005 18:27:39
? I just converted a Farmall H to propane. It runs so good I also want to convert my MM Jet Star 3 Super to propane. Propane --- either you love it or hate it...
I think you would basically need the gasoline carb and gasoline tank. Take the all of the propane stuff off and replace with the gas stuff. Basically plug the water lines that go to the converter. You most likley will have a higher compression ratio, but i'm not sure what, if any problems you would have running on regular gasoline.
If you do convert let me know about the Lp stuff.
