Minneapolis Moline Tractors Discussion Forum
MM's Thirstiest Gas Tractor
Curious
01-06-2005 10:13:02
What was MM's biggest gas tractor and how many gallons per hour could it burn? Thanks.
Jim Calhoun
01-10-2005 18:07:39
 Re: MM's Thirstiest Gas Tractor in reply to Curious, 01-06-2005 10:13:02
I know this is not anywhere near the most thirsty, buy my old U is a gasoline junkie. I can run my Z 3 times as long and my Massey 44 twice as long on a gallon of fuel.
Don't get me wrong, I love my U and use it often, but I use the Z as much as possible to save a dollar here and there.
Kelvin
01-08-2005 17:08:40
I know its not a tractor, but i heard about a 605 powering a sawmill here in NC that wouldn't run a whole day on a 55 gal drum of gasoline.
Dieselbear
01-06-2005 13:53:16
I've got a G-1000 Vista gas,it is very discriminating, only runs on high test. It likes it so well that we only use it for light work. I don't have my own gas truck. Glenn
David
01-06-2005 11:02:08
Do you mean just gasoline or lp gas included? If it is just gasoline then the G1000 gas would be the biggest, not many made though. My uncle had a G900 gas that was quite thirsty.
larry h
01-06-2005 15:19:17
 Re: MM's Thirstiest Gas Tractor in reply to David, 01-06-2005 11:02:08
1355 8 gal per hour 148 hp we have one
Glenn F.
01-06-2005 14:33:56
I guess I would like to revise my question. What is the biggest LP MM, and how much fuel will it use under a heavy load?
Mopower
01-07-2005 05:36:30
 Re: MM's Thirstiest Gas Tractor in reply to Glenn F., 01-06-2005 14:33:56
The thirstiest MM by far would be a G1350, G1355, or A4T-1600 made with the 800 LP gas engine. There was also a supercharger and/or turbo I have seen installed on these. Matt Nunez in Louisiana had a G1350 800 LP Supercharged. Has to be by far the thirstiest tractor MM had unless you want to talk about the 1210 power unit.
steveormary
01-06-2005 22:01:04
Dont know about the big ones but this was a big one to me at the time. And that was summer 1956.
3 gal/hr MMUB on LP. Mabe a little more.
redwhite
01-10-2005 18:05:58
 Re: MM's Thirstiest Gas Tractor in reply to steveormary, 01-06-2005 22:01:04
general rule was gal per hp.
