Minneapolis Moline Tractors Discussion Forum
REMOVE BLOCKS FOR VALVE JOB?
JKC
12-31-2004 05:55:13
I am going to attempt to do a valve job on my 1950 MM ZAU. If I am reading the Shop Manual correctly, it says that in order to do that, I have to remove both blocks. Am I reading that correct? Can someone elaborate on it for me?
Thanks very much.
dlp
12-31-2004 07:14:35
 Re: REMOVE BLOCKS FOR VALVE JOB? in reply to JKC, 12-31-2004 05:55:13
If you plan to lap the valves, just pull the head & valve covers & reseat them. But if you take the rod bearings loose & pull the blocks off, it a simple job then to do a top end.
