Minneapolis Moline Tractors Discussion Forum
Hydraulic Ram UB Special
JohnUBTexas
12-28-2004 07:45:17
Is there an aftermarket Ram or Other that has the characteristics of the OEM MM ram, I need a dual action Ram that stays up when pump is neutral, I have read about a 'Pilot Controlled cross-port check valve' but am unsure of which one to buy to use a regular ram. A part number manufacturer for this valve would be great or a ram that works with the UB Hydraulic spool and pump.
Mike Tessman
12-28-2004 15:59:14
 Re: Hydraulic Ram UB Special in reply to JohnUBTexas, 12-28-2004 07:45:17
John: Where are you located in Texas? I have several UB Specials and other U's with the original hydraulic cylinder! Let me know if i can help you in any way? Phone 830-254-3253. Mike
johnUBTexas
12-28-2004 18:15:52
 Re: Hydraulic Ram UB Special in reply to Mike Tessman, 12-28-2004 15:59:14
Thanks Everyone, Mike I will call, you are about 6 hours south of me , do you get alot of sea spray corrossion down there? I just bought this UB from a guy to use with a shredder, I originally had no interest in restoring it. It ran , It was Cheap , I bought it. So far a really good purchase solid tractor. I hope to get this cyl/ram fixed and get to cutting and maybe restore it a lil later on, or trade it to a MM collector who wants it more than me. :)
Kelvin
12-28-2004 17:49:57
Jim, a source for a check valve that will work is Welter's farm Supply, Verona MO. 417-498-6496. They also would probably have parts for the original-type cylinder if you decide to go that route.
I've never used one of those check valves myself, (not on Molines, anyway) But Welters has never steered me wrong on other stuff I bought from them. And I do know that the 'hump' on the side of the original cylinder does that same function.
Larry O.
12-28-2004 08:42:22
This is what you wan't. Then you can use any cyl..
http://www.northerntool.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=6970&productId=36718&R=36718&issearch=2070
