Minneapolis Moline Tractors Discussion Forum
Help serial number - Jet Star 3 Super
WayneT
12-24-2004 15:44:47
I have a Jet Star 3 Super Gas that I am trying to get parts for. Serial number off of tag is 16312431. Nothing matches with numbers posted on Internet. I always thought it was a 1967 or so. They supposedly had two different distributors used on them. Trying to figure out which distibutor it has. No tag or number on outside of distributor. Any numbers on the inside? Haven't tore apart yet. Any help out there? Thanks...
BMG
12-24-2004 17:46:56
 Re: Help serial number - Jet Star 3 Super in reply to WayneT, 12-24-2004 15:44:47
Wayne,
You've posted the serial # from the engine. You have a 1968 206L-4 engine. The tractor serial # is located on the trans housing and should look like "28304XXX" for a 1968 Jet Star 3 Super gasoline/LP.
Brian
WayneT
12-25-2004 08:36:53
 Re: Help serial number - Jet Star 3 Super in reply to BMG, 12-24-2004 17:46:56
Thanks... you know now that I think of it,it was the engine serial#
Kelvin
12-24-2004 16:26:19
If your distribuitor has clips, it is the old style and uses NAPA CS763A points.
If the cap has screws holding it on, and the housing is aluminum, it is the newer style. points are the same set (I Think) as '66 chevy 250 6 cylinder.
WayneT
12-25-2004 12:42:56
 Re: Help serial number - Jet Star 3 Super in reply to Kelvin, 12-24-2004 16:26:19
Thanks...that helps alot
WayneT
12-25-2004 08:45:01
