Minneapolis Moline Tractors Discussion Forum
Minnie Moe Hydraulics
Lonely oak draf
12-23-2004 11:46:15
I Have water in my Hydraulic system and the manuel doesn`t give clear directions on how to drain system.Any help would be appreciated.
JK2
12-25-2004 05:59:07
 Re: Minnie Moe Hydraulics in reply to Lonely oak draft, 12-23-2004 11:46:15
Since the 60's, when draining systems that don't have a separate power steering pump, we disconnect the line that goes to the power steering at the hyd pump (or remove the plug from the pump if there is no power steering), connect a short line or hose to the pump and put the other end in a container then start tractor at an idle. Turn tractor off as soon as the system is empty. Don't run above an idle or let it run after it is empty or the pump will be damaged.
John
grandfield
12-24-2004 14:45:20
There is a drain plug, may incorporate the filler/dipstick on the lower righthand rear corner of the 3 point unit, then it's just a question of getting the water out of the rest of the system, maybe someone else has experience with that part and will help.
LONELY OAK DRAFT
12-23-2004 20:22:45
THE TRACTOR IS AN M602 DIESEL THE MANUAL LISTS IT AS A TYPE E HYDRAULIC SYSTEM.
grandfield
12-23-2004 18:11:03
Would be very helpful to know the model and approx.year of the hyd sys in question.
