Minneapolis Moline Tractors Discussion Forum
crank bearings in a ub diesel
roland withersp
12-21-2004 16:27:22
how do you get them out without taking crank out?
Kelvin
12-22-2004 19:22:06
 Re: crank bearings in a ub diesel in reply to roland witherspoon, 12-21-2004 16:27:22
This works on smaller engines and may work on a U-get a cotter pin big enough that each half is almost but not quite the thickness of the bearing insert. bend the halves to a 'T' shape, and stick it in the oil hole in the crank. Your T may have to sort of run at an angle so the 2 legs will fit flat against the crank.
loosen all the main caps about 1-2 turns. remove the cap from the bearing you want to remove.
Then stick the cotter pin in the oil hole, and rotate the crank toward the side OPPOSITE the locator tab on the bearing. The cotter pin should snag the upper insert and roll it out on the crank. Of course, you remove the half in the cap the regular way.
Mopower
12-22-2004 05:14:13
I wasn"t sure this could be done. I"ll have to ask a few people. I have a good UBD. Where are you in Michigan? This isn"t Peter is it?
