Minneapolis Moline Tractors Discussion Forum
Minny or Avery BF
Sam G
12-21-2004 04:33:59
I recently purchased this tractor and cant seem to find any type of serial number located on the frame rail as I was told. All that I do have is a motor number of 2454888. Is this anything to go off of? Is there any other place to check for numbers? The tractor looks to have been painted yellow underneath with a top coat of red,,Any help would be greatly appreciated,,Thanks
Kelvin
12-22-2004 19:37:07
 Re: Minny or Avery BF in reply to Sam G, 12-21-2004 04:33:59
Avery didn't make BFs. They made A's V's and Rs.
There are 2 versions of the A. Both have grilles with horizontal bars, the early grilles sloped back from bottom to top. The later grilles curved back at both the top and bottom. If they had hydraulics they used a hydraulic reservoir/cylinder/control valve assembly hung on the right frame rail.
V's used a smaller engine. (ZXB) and had a flat grille with horizontal bars. Depending on year some wer made as Averys and some were made as MMs.
The serial number for a V is on the top of the right frame rail, near the carburetor.
BF Avery introduced the R right before the merger. So you see red R's as well as some yellow Rs. they used the same engine and transmission as the A, but the grille on an R is made of rippled sheet with thousands of tiny punched holes in it. They still used the same hydraulic reservoir/cylinder/control valve as the Avery A.
Minneapolis Moline added their uni-matic hydraulic system to the Avery R and called it the BF. The main difference is the cylinder is separate from the MM type reservoir/control valve assembly which is under the fuel tank.
I read somewhere that the serial number on early Averys and Cletracs is on the frame rail, near where the operator's right foot rest is. It may be on the undersize of the rail.
I hope this helps you identify yours.
SamG
12-23-2004 04:11:02
 Re: Minny or Avery BF Kelvin,,have calendar that in reply to Kelvin, 12-22-2004 19:37:07
The reason that I am a bit confused on what this tractor may be is because of a calendar that shows the 1951 mm bf, it says it was built by avery and it made its debut in 1950.It goes on to give specs about the tractor. Also says the bf didnt wear its avery namesake paint scheme for long. Avery was acquired by mm in 1951 and mm continued to build the bf, now painted in the mm prairie gold. So still not sure what it what,,its hard to find anything on the tractor that has a stamped plate..thanks for your info and i hope maybe this gave you some additional info...The source of the calendar is Historic Farm Tractors by Dave Arnold and is a 1997 year..thanks for all your info...
Gary Duff
12-21-2004 21:08:25
The Avery has the serial # stamped in the right frame rail and the MM BF has a serial # plate fastened to the right frame rail side about 2 feet ahead of the brakes.
