Minneapolis Moline Tractors Discussion Forum
Got her home Kevin
woodrow
12-20-2004 04:26:10
Well it was a long day but it ended in success. The older gentleman allowed the gtc would run. After about four hours of making a make shift wiring harness, cows have chewed original all off, Two sets of jumper cables, Filling and resetting points, and by-passing the starter selenoid, I got it to fire. Now I got here home and the work has commenced.
The rear diff had about 5 gal of clean drining water on bottom, and 20 gal of brown sludge. How much does this thing normaly hold.
I have been reading and the GTC engine is supposed to be a mixture of G and U engine parts. The factory was afraid a straight G 403 ci engine on propane would be more than the chassis could take. Any one know exactly what is in my 340a-4 engine
Mopower
12-20-2004 05:14:44
 Re: Got her home Kevin in reply to woodrow, 12-20-2004 04:26:10
We've got an old 340 in our UB, (came out of a UTU and before that a GTC). The engine has a 4.25" bore and 6" stroke making it smaller than the 4.625" bore 403. Later, I don't think they found a 403 motor would be too powerful for the chassis on LP simply because all GB LP were 403. It seems to be a good motor although we are switching the small bore over to the large one eventually for more h.p.. The blocks are taller like the G, but smaller bore like the U. A few 340 engines were used in UTIM models. I have a U photo book that shows some factory UTI with the tall blocks. Not sure if they were testing or if a few were sold that way. Hope this helps. Good luck on your project.
