Minneapolis Moline Tractors Discussion Forum
MM BF wiring meltdown
WAS
12-19-2004 15:47:00
After using my MM BF for over an hour it suddenly developed a melt down in the wiring on the backside of the ammeter. To verify the simple things, is this a negative or positive ground system? The ammeter was reading to the right during operation. Any ideas on cause or repair?
D.P.M.
12-19-2004 18:09:15
 Re: MM BF wiring meltdown in reply to WAS, 12-19-2004 15:47:00
If it has the original 6 volt system it will be a positive ground.As to what caused your melt down it has most likely developed a short,I would be checking the battery cable to the starter and the charging system wires,I may be able to supply you with a wiring diagram if you need it,This would be for a original system.Good luck.
