Minneapolis Moline Tractors Discussion Forum
MM ID
RichardSC
12-17-2004 05:02:20
A friend bought an MM at an auction and the serial number tag is missing. Can we tell from the casting numbers what model and year it is? We are JD and Case people and know nothing about MM, but are anxious to learn.
Thanks, Richard
BMG
12-17-2004 13:17:24
 Re: MM ID in reply to RichardSC, 12-17-2004 05:02:20
Richard,
Most MM tractors have a serial number tag on the engine and on the transmission. Are both tags missing? The tractors serial # tag is mounted on the trans. It's usually on the right side on the older models and on the left side on the late models (60's vintage). If you post some casting numbers from the engine and trans we should be able to identify the model. The year may be tougher to figure out without any serial #s.
Brian
RichardSc
12-17-2004 16:28:33
 Re: MM ID in reply to BMG, 12-17-2004 13:17:24
Thanks for the info.
I will check and see.
Richard
