Minneapolis Moline Tractors Discussion Forum
M670 Parts
Herald
12-13-2004 20:13:00
I have a 1966 M670 and need some front end parts for it. Is anyone in the Minnesota-Iowa area parting one out? Or any salvage yards that would have one, I would be interested in buying some parts off it. Also where can you get a repair catalog for the same tractor? Thanks for any help. Herald
JoeMN
12-15-2004 15:31:25
 Re: M670 Parts in reply to Herald, 12-13-2004 20:13:00
I saw a 670 with loader,beefed up frt end by putting G1000 row crop axle on it. Should you want that, I could fix you right up. Perhaps some of the knowledeable contributors to this forum could tell us if that is a simple bolt in replacement or a complicated procedure. In Central MN 218 924 4044.
R.D.F.
12-14-2004 11:02:36
Open your email so people can contact you or email us, we probably have all you need, Dale
Herald
12-14-2004 21:24:58
 Re: M670 Parts in reply to R.D.F., 12-14-2004 11:02:36
R.D.F.Where are you located? And do you work on MM's? My e-mail is [email protected] Thanks.
Augie
12-14-2004 06:18:24
What kind of front end parts do you need?
Herald
12-14-2004 07:17:26
 Re: M670 Parts in reply to Augie, 12-14-2004 06:18:24
Augie,On a wide front, I need the steering housing,the piece that the front axle clevis bolts to,and the clevis and pin plus the reach support and probably the support arm. And then the pull link support on the 3 point. The part that bolts to the tractor frame. Plus maybe more as I havn't got into it any further yet. I bought this tractor on e-bay and was supposed to be in "excellent"shape."New paint" with spray cans, gauges all work but don't What a surprise when I got it home and got to looking at it. Never buy off e-bay again. Thanks for any help. Herald
Augie
12-14-2004 10:02:53
 Re: M670 Parts in reply to Herald, 12-14-2004 07:17:26
I've got a complete adjustable front axle but I don't have the stuff that you need. Have you called Welter's to see if they've got a 670 on the yard for salvage?
You'll really like the tractor once you get it all fixed up.
