Minneapolis Moline Tractors Discussion Forum
MM Hydraulic Pump
Paul Muma
12-13-2004 15:52:42
I have a MM Z that I have acquired a camshaft gear driven original hydraulic pump for. Problem is, the donor tractor was missing the engine oil fill cap and the roller bearing in the pump was damaged by moisture. The pump itself is a o.k. as there was fluid in it. I have disassembled the pump and need a roller bearing and seal. Hard to read but the number on the bearing reads- mpc 304s, and I see no number on the seal. Anyone have any idea of what the correct replacement bearing and seal should be?
MMSTEVE
12-13-2004 18:37:03
 Re: MM Hydraulic Pump in reply to Paul Muma, 12-13-2004 15:52:42
A FRIEND TURNED ME ON TO KAMEN INDUSTRIAL FOR IHC AND MM BEARINGS JUST CALL THEM WITH THE NUMBER OFF YOUR BEARING AND THEY CAN CROSS REFERENCE FOR YOU. THEY ARE CHEAPER TOO.
Kelvin
12-13-2004 17:41:44
I suggest calling Wendell Everett 740-922-3335. He has helped me with parts for later MM hydraulic pumps.
