Minneapolis Moline Tractors Discussion Forum
Minneapolis Moline Compression Tests
Jackie Parris
12-10-2004 09:21:50
I'm in the process of restoring a 1951 ZAU MM. I ran a compression test and it scored a 90. The test was done using the manual crank instead of actually starting the engine. I just ordered the owners manual and it hasn't come in yet.
Can someone tell me if a 90 is good or bad? I'm not sure if I'm going to need new rings or not.
Thanks for your help
old
12-10-2004 09:52:34
 Re: Minneapolis Moline Compression Tests in reply to Jackie Parris, 12-10-2004 09:21:50
Thats not to very bad considering how you did it. Could be higher but it will probably run well that way and it will probably get a little better after you get it started
