Minneapolis Moline Tractors Discussion Forum
RT 100
Dale L
12-05-2004 09:46:42
I just helped my neighbor put a rebuilt mag on an RT 100. We got it running but it's not running the best.Is there a way to adjust the timming ? To me it looks like you bolt on the mag and that's it. Hopefuly a new set of wires and plugs will fix it.It's been sitting for a few years.
M Hornick
12-05-2004 20:15:39
 Re: RT 100 in reply to Dale L, 12-05-2004 09:46:42
You might want to pull the two side covers off and check that the valves are moving freely. They might be gummy after sitting. Mike
SWMolines
12-05-2004 15:07:20
If you loosen the bolts your tightened when installing the mag, you should be abale to rotate the mag just like you would a modern distributor. You do need to loosen both of the bolts.
Good Luck!
old
12-05-2004 14:24:14
Never heard of a RT-100 its probably an RT or R or RTU my RTU has RT-100 on a number of parts but its really an RTU. Did you put new points and condenser it the mag? if not that could be part of the problem
