Minneapolis Moline Tractors Discussion Forum
'67 Jet Star 3 Super-resistor in ignition line to
WayneT
12-01-2004 18:33:17
I have a '67 Jet Star 3 Super that has a mid-1980's Delco-Remy alternator (has internal regulator). I seem to go through alot of condensors, one every 100 hours or so. I suspect something to do with the igniton lines.
A few years ago when I converted a Farmall from 6 volt to 12 volt, I was told to put a resistor in the ignition line that goes to the coil. Supposedly all coils are 6 volt. Any body know anything about this? I think without the resistor a coil would get hot. The MM coil does not, however. Thanks in advance.
R.D.F.
12-02-2004 06:30:18
 Re: '67 Jet Star 3 Super-resistor in ignition line in reply to WayneT, 12-01-2004 18:33:17
We solve that by installing an electronic ignition, no more problem, sell them here if you chose. Dale
gary lee
12-02-2004 12:11:33
 Re: '67 Jet Star 3 Super-resistor in ignition line in reply to R.D.F., 12-02-2004 06:30:18
not all coils are 6 volt, and your correct, if your putting 12 to a 6 it will get hot and eventually burn out the coil. i had one do this once and found that my regulator in the alternator was running at 15.5 inplace of 14.7 as it was suppose to, and further investigation i found a bad ground wire that was corroded and thus caused my alternator to put out more. have you tried a different coil? i have had coils that go bad and burn out resitors as well.
wayne ratliff
12-03-2004 12:40:25
 Re: '67 Jet Star 3 Super-resistor in ignition line in reply to gary lee, 12-02-2004 12:11:33
sounds like you have a 12 volt system and a 6 volt coil get a 12 volt coil and resistor from any parts store put the resistor in line on the ing side of the coil
WayneT
12-02-2004 16:11:58
You know...that sort of makes sense to me. About time for a few new parts anyways. Thabks...
WayneT
12-02-2004 16:12:29
Jerry Cent. Mi.
12-03-2004 12:43:40
 Re: '67 Jet Star 3 Super-resistor in ignition line in reply to WayneT, 12-02-2004 16:12:29
Most distrubiters use 6 volts and you can buy a six volt coil but if you have a 12 volt battery a resister is required between the battery and coil. You can purchase a 12 volt coil with an internal resister that drops the output to 6 volts. With a 12 volt coil and battery use a resister between the coil and distrubiter.
