Minneapolis Moline Tractors Discussion Forum
BF Avery Rims
Mark Mundahl
11-19-2004 20:36:08
I'm restoring a 1954 MM BF Avery. The rims are rusted through at the valve stems. They are 30" x12" and they are adjustable on the axles.
Kelvin
11-20-2004 16:18:28
 Re: BF Avery Rims in reply to Mark Mundahl, 11-19-2004 20:36:08
30" Adjustable rims? What is the tire size?
Do they bolt to the drive plate (That has the lug bolts in it)
2 thoughts:
1. Would the drive plate fit in a 28" wheel? they're a lot more common than a 30" wheel.
2. How big is the hole? I've seen a welder put a patch in the valve stem hole, move over to another spot, swage the rim and put a 5/8" hole for the valve stem. When it was painted, you couldn't find the patch.
MMjohn
11-20-2004 03:50:28
I used a rim off a farmall a on my MM BG John
