Minneapolis Moline Tractors Discussion Forum
UTU 12V light bulbs?
savsmm
11-13-2004 10:04:30
Converted my '50 UTU from 6 volt to 12 volt. Has anyone found 12V light bulbs for the front headlights that would fit right in.
Kevin Moschenrose
11-13-2004 20:04:30
 Re: UTU 12V light bulbs? in reply to savsmm, 11-13-2004 10:04:30
If you are still using the old style reflector in them with the three studs you can get that style bulb from most antique auto car parts places. If you have the newer style bulbs that have the two pins on the bulb base than you can get those at any RV camper place. Both styles of bulbs have the big wide glass in them.
deadeye
11-14-2004 03:24:16
 Re: UTU 12V light bulbs? in reply to Kevin Moschenrose, 11-13-2004 20:04:30
I think, if I remember correctly that I once went to the farm store and bought the brightest 12v light bulb that I could get with the 2 pins and then took the ring off of the old 6v bulb with a soldering iron and put it on the 12v bulb. Polish the brass or sand the bulb a little with sandpaper and use a little flux on it. Worked for me....deadeye
