Minneapolis Moline Tractors Discussion Forum
Heads on 403
MMjohn
11-08-2004 14:54:54
which head is best on 403 10a 4209 or GE 30J for stock rpm pulling thanks John
j
Andy2
11-10-2004 20:15:13
 Re: Heads on 403 in reply to MMjohn, 11-08-2004 14:54:54
If you"re just pulling for fun, use 4209"s you can pull well with pump gas. If you run GE 30j"s on a 403 you will have to high octane,(race fuel) all the time to prevent detonation. If your tractor is LP fueled, use the 30J"s. They are shorter heads and may require different headbolts and pushrods.
Mopower
11-09-2004 13:21:18
The GE30J is more compression. The 10A4209 has smaller plug holes for normal size spark plugs. 4209 would be a clean running good lugging motor, but a 30J would pep it up a little.
