Minneapolis Moline Tractors Discussion Forum
MM Z wireing
Larry O.
11-04-2004 14:49:34
I got a 1952 Z I am working on. The wires were all burnt off. I need to know where the wire that hooks on the L (line) on the voltage reg. connects to on the dash switch. Or a wireing diagram would be nice too. Email [email protected]. thanks Larry
Kelvin
11-04-2004 18:52:25
 Re: MM Z wireing in reply to Larry O., 11-04-2004 14:49:34
The 'L' on the regulator connects to the "BAT" terminal on the 5 position switch.
FYI:
The 'BAT' terminal on the regulator goes to the ammeter, then from there to the hot post on the starter solenoid.
A wire from the battery side of the ammeter goes to the starter push button. Then another wire goes from the starter push button to the actuating terminal (small terminal) on the starter solenoid.
Hope this helps.
Larry O.
11-05-2004 03:35:00
 Re: MM Z wireing in reply to Kelvin, 11-04-2004 18:52:25
Thank You. Now I can get her running.
