Minneapolis Moline Tractors Discussion Forum
How can I tell what it is??
old
10-30-2004 07:23:39
Going to go look at what a guy belives is an MM this morning and if it is how/where do I find the ID of this. I know its a trike and also know it has a spot for a hand crank up front but at this times thats all I know. Is there a way to norrow it down some by this
moline
10-30-2004 08:08:25
 Re: How can I tell what it is?? in reply to old, 10-30-2004 07:23:39
Check by the belt pulley on the right side below the brake pedals,there should be a data plate there which will give the model and serial number of the machine.There is also a data plate on the engine if the other one is gone.The engine plate will give bore and stroke but will not tell you the model of the tractor.Post back if you can only find the engine plate,someone here can narrow down the machines by the engine size.Hope this helps!Moline
old
10-30-2004 13:19:53
 Re: How can I tell what it is?? in reply to moline, 10-30-2004 08:08:25
Well I found out its an R serial number 416985 any ideas of what year it is. Also how much might it be worth, looks good may have a newer paint job on it. Both rear tires look good to very good 11.5-36s. Hasn't been run in a year or so but isn't stuck. No hydralics, trike, hand clutch. Any guesses on what it would be worth. Thanks
Kevin Moschenrose
10-30-2004 14:44:01
 Re: How can I tell what it is?? in reply to old, 10-30-2004 13:19:53
1947 RTU the price on what it is worth depends on a matter of perspective and also location is another in this great land it is at too.
