Minneapolis Moline Tractors Discussion Forum
MM U and hd 800
Webb
10-27-2004 18:07:28
Can a HD 800 be put into a mm u for pulling
if so who can do it
MIB
10-28-2004 16:24:06
 Re: MM U and hd 800 in reply to Webb, 10-27-2004 18:07:28
IF you want to put the long input shaft and large bell adapter from a 6 cylinder it would fit or make yourself a small bell 800 out of a 504 diesel crankcase with 800 blocks on it and a 605 crank in it.
Andy2
10-28-2004 11:02:16
No, the bell housing on a U is much smaller. A HD is a 6 cyl and a U is 4 cyl. I doubt if many rules would let you pull a 6 cyl U. You can,(with some work and $$$$) put HD blocks on a U crank case and use HD heads.
