Minneapolis Moline Tractors Discussion Forum
U Moline blowing out antifreeze
Keith Giffin
10-26-2004 16:19:05
I was plowing with the U and it started blowing out anitfreeze through the overflow at high RPM. Filled the radiator and it does just fine at low RPM but rev it up and it pushes the antifreeze out. Any ideas as to what is going on? Thanks
Kelvin
10-26-2004 18:33:30
 Re: U Moline blowing out antifreeze in reply to Keith Giffin, 10-26-2004 16:19:05
I had that problem too. My U had a 403 and I was plowing in 4th gear. It could work O.K. all day in 3rd. I had too much engine or not enough radiator, depending on your point of view.
By chance, have you removed the thermostat? A thermostat will slow down the speed your coolant goes through the system, because it has a smaller opening than anywhere else in the system. Of course, if you install a new thermostat, it needs a 1/8" bypass hole in it so that it will open as soon as the water in the block gets hot.
Does it use a pressure cap, or is it the old style-like a gas cap? I'm not sure this affects your problem, but a pressure cap will allow the engine to run a little hotter with no cooling problems.
How full are you filling the radiator? It takes about 5 gallons to fill a U and 5 gallons will expands right much from 80 degrees to 180 degrees, so if you have it close to brimfull cold its bound to lose some coolant when it warms up.
There's also a chance your radiator is plugged up, or you have a lot of scale in the blocks and it is retarding cooling.
These are just some ideas to get you started.
Bob M
10-26-2004 18:19:46
Keith - Could the radiator be overfilled? On my 47 UTU with the engine cold the coolant level must be no higher than about 1-1/2" below the filler neck. Otherwise when the tractor is worked hard (temp gage showing 180 - 200 deg)it'll puke antifreeze out the overflow until the level gets back down where it wants.
keith Giffin
11-01-2004 16:59:03
 Re: U Moline blowing out antifreeze in reply to Bob M, 10-26-2004 18:19:46
Thanks for the info. I do not think it was over full. It had been used to plow with about a week ago and it was fine. Then it started pushing the antifreeze out. Again Thanks
