Minneapolis Moline Tractors Discussion Forum
Radiator Replacement
Texas Red
10-17-2004 09:10:23
Just came home with a 49 MM UTS. It neads some radiator work done on it. If the core is bad, what other models have the same radiator that is a bolt on fix. I am new to world of MMs and wating for the new manual to come in. Thanks for any help at all. Thanks TR
Oklahomatractorrebuilder
10-19-2004 20:56:43
 Re: Radiator Replacement in reply to Texas Red, 10-17-2004 09:10:23
I have a raditor that I bought for our UTS from a guy in Colorado that we had rebuilt after we got it I would like to sell. Gave $100.00 for it and will take $75.00 for it. Just want to get it out of our way. We decided after spending so much to rebuild the motor, new tires, new paint, rebuilding transmission & rear end to just buy a new radiator for ours. Located just north of Wichita Falls in Oklahoma. 580-355-0136
LW
10-20-2004 17:12:04
 Re: Radiator Replacement in reply to Oklahomatractorrebuilder, 10-19-2004 20:56:43
Where did you find the new radiator?Would like to know, thanks
grandfield
10-20-2004 19:53:54
 Re: Radiator Replacement in reply to LW, 10-20-2004 17:12:04
LW, My brother has a radiator shop, he can look up the core and order it from his supplier, then put my upper and lower tanks on it. Also got one for a Brown Jet and one for a GTB.
10-20-2004 19:36:47
A friend of mine owns a raditor shop in Apache, Oklahoma. He called some friend of his in Iowa and I got a new raditor in two weeks. I do not know for sure where they found it, just know they did and it only cost $400 for it. Tim
Mike Sieber
10-24-2004 10:55:12
 Re: Radiator Replacement in reply to Oklahomatractorrebuilder, 10-20-2004 19:36:47
I recently aquired two new old stock minneapolis moline radiators,one is for a ut,and the other is for a R.The one for the UT is still in the crate,and the other is in mint condition!!I will sell them for 250.00 EACH or 425.00 for the pair. Mike Sieber(402-724-3149)McCool Jct.Neb.
carl grey
10-19-2004 04:45:18
i am in northeast texas and have couple of tractors i am parting out that radiators still on them that are in good shape, let me know if i can help out
Texas Red
10-19-2004 16:14:18
 Re: Radiator Replacement in reply to carl grey, 10-19-2004 04:45:18
Hello Carl. Give me a call at 940-549-4665 or sind me you E Male adress. i would like to talk to you about the rad.
CARL GREY
10-20-2004 19:09:27
 Re: Radiator Replacement in reply to Texas Red, 10-19-2004 16:14:18
I WILL CALL THURSDAY EVE, TO LATE THIS EVENING CARL
Kelvin
10-18-2004 19:04:16
Any model U-UTU,UTE,UTN,UTS (Except perhaps the early ones with red face grille 39-41) should be a direct fit. A UB radiator will work, but requires a larger hole in the hood, the pressure cap is larger. The hole in the hood will also need a notch on the side for the overflow drain.
I know its expensive, but I'd suggest take the $100-$150 you'll likely spend on another old radiator and spend it (plus about anopther $200) on another core for the radiator you have. Then you'll have a good-for-the-next-40-years radiator.
Ol Chief
10-19-2004 19:16:23
 Re: Radiator Replacement in reply to Kelvin, 10-18-2004 19:04:16
Hi Carl;I am in the Hill Country and have afew MM's.Can use some parts if same tractors.I do not know how to reach you. My phone is 1 830 997 8296 My conputer e-mail is out of order so would be unable to reach you that way.Tks. John Cooney
