Minneapolis Moline Tractors Discussion Forum
403 GB
Jerry Cent. Mi.
10-17-2004 04:40:27
I pull with a 403 GB and want to put a little more zip in it. I was thinking about having some cam work done and I saw an earlier post about advancing the timing by moving the crank one notch. I need more information about cam work and the advance procedure.
Andy2
10-18-2004 22:00:36
 Re: 403 GB in reply to Jerry Cent. Mi., 10-17-2004 04:40:27
I have not done this but heard it increases the midrange tourque. If you use this tractor in the field I would be hesitant to do this; your egt's could get hotter and you could burn valves or crack heads. berry cam has several good grinds depending on what you are looking for. 320-395-2377
MMSTEVE
10-17-2004 19:41:29
I SAW THAT ALSO AND AND WOULD BE CURIOUS TO HEAR ABOUT IT TO. I TALKED TO A GUY THIS SUMMER BUT HE WAS PULLING AND I DIDN'T GET TO FINISH THE CONVERSATION. THAT WAS ONE OF SEVERAL THINGS HE HAD DONE. I PULLED CARS & MOTORHOMES OUT OF THE SAND AT THE LAKE THIS SUMMER. PLUS PULLED SOME OLD SUBMERGED STUMPS WITH MINE NO LACK FOR POWER.
JUST NEEDED ALITTLE MORE WEIGHT IN FRONT
